Posted: Sun, 27 Feb 2005 23:02:36 Post Subject: Enermax Maxflow CS-718B ATX Case |
 | As nice as the exterior of this case is, the interior is what really sets this case apart from the rest. The “wind tunnel” design is without a doubt the most innovative, and eye catching, feature of this case. Coupled with the inverted motherboard design, a decent boost to the system's cooling performance should be expected while using the Enermax Maxflow. - The Review |
Last edited by Doctor Feelgood on Tue, 02 May 2006 16:57:01; edited 1 time in total |
OneAppleMan Rated PG
Posted: Mon, 28 Feb 2005 13:11:12 Post Subject: |
dadx2mj Happy Camper
Posted: Tue, 01 Mar 2005 20:46:38 Post Subject: |
Cool
The one I got is already in peaces. I striped it down to get ready for its paint job. That side window was just screaming "Hal 9000" at me so here I go.
As far as if it as good at the Enermax I would have to say so. The two cases are exactly alike as far as the frame goes. I could not get is to warp at all. Even after my 250 a$$ sat on it without any of the outer panels on. The only difference that I could see was that the plastic shroud was a different collor and the the Enermax has a few extra things like the power supply, LCD display with alarm, fan RPM, Aluminum dial to control up to 4 fans, and blue LED Fans (in the Aerocool it just has two regular fans). I mean even the feet and the look like they are the same.
I would have to say the only thing that I do not like is the metal too-less mounts for the 5.25" and 3.5" bay components. But I can live with it
As far as the Enermax, just to much has been done to it. Before I bought my Aroocool I always said that I would never buy a premoded case but the Aroocool case was perfect with the window and that was it. Plus look at all the room for a water kit  |
xenophobe Rated PG
Posted: Thu, 02 Aug 2007 21:31:43 Post Subject: |
No problem on the old thread bump... hopefully the reviewer will come online soon and give his opinion.
I would say some older cases are some of the better ones out there. Although I never used this one, I had an older Enermax (5-6 years old) case I would probably still be using if I didn't 'loan' it to someone...  |
Modulok Rated XXX
Posted: Thu, 02 Aug 2007 21:38:46 Post Subject: |
| Doctor Feelgood wrote: | I had an older Enermax (5-6 years old) case I would probably still be using if I didn't 'loan' it to someone...  |
ok, don't be surprised if it ends up on your doorstep in the near future.  |
